Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: PTO engaged, will not disengage
jim wieringa
07-20-2013 13:29:05
1966 Ford 2000 3 cyl gas w/ 6 speed trans.
welding man
07-20-2013 15:35:08
 Re: PTO engaged, will not disengage in reply to jim wieringa, 07-20-2013 13:29:05
Jim,all you are doing is coupling 2 shafts together and disconnecting them. There has to be a reason the collar is not moving back far enough to release them. Is the groove in the collar worn bad? you said you had to replace the shift lever. Why? Is there any end ply in the PTO shaft?
jim wieringa
07-20-2013 18:51:42
 Re: PTO engaged, will not disengage in reply to welding man, 07-20-2013 15:35:08
I just had my son take a look inside the casing and he thinks the shift collar will not mesh with the gear foreword the tractor because the splines are all messed up. I looked in my service book and cannot identify that gear. If I pulled the PTO shaft out the back will that allow me to remove the gear that the shift collar mates with? Maybe take it out the side hole...
welding man
07-20-2013 20:27:48
 Re: PTO engaged, will not disengage in reply to jim wieringa, 07-20-2013 18:51:42
Yes the pto shifter needs to be engaged when pulling the PTO shaft to keep the collar from falling into. the case.
Copyright © 1997-2015 Yesterday's Tractor Co.
