TractorLinks.com
Show Parts for Model:
Re: Sos Guru Question Pto issue
Tequila
07-20-2013 07:47:09
I am not your guru, but perhaps can help a little. The SOS with the two speed PTO is called the deluxe SOS , and should also have an additional lever on the left side, aft of the running board for ground speed control. The cable you pull does not turn, simply activates a hydraulic valve which engages the PTO clutch. The two speed lever you mention switches inside the casing and is lubricated with hydraulic fluid, assuming the fluid level is correct. The shift lever is steel mounted on an aluminum spline. Famous for breaking the shaft if corroded on. You don't want to have to find another. No longer available at CNH. Very pricey if you find one. Sounds like the two speed lever is not centering in neutral. If all other aspects work, I would live with it. Hope this helps.
