TractorLinks.com
Order Ford NAA Parts Online
Re: ford naa
WayneIA
07-19-2013 20:34:33
There is no screen. The hydraulic pump is located at the rear of the engine on the right side. Does the pump look kinds square with an adjustment on the front? (vane style pump) Or does it look kinda round with a 3/8s pipe plug towards the top front?(piston type pump) Sound like you have a vane style pump. and your indication suggests that it is wore out. I believe parts are still available for the vane pump,( short life) but very expensive. Most change over to the piston style pump,(longer life and cheaply repaired) and in so doing ,will need the proper hyd lines for the piston pump also
big farmer
07-20-2013 08:41:10
 Re: ford naa in reply to WayneIA, 07-19-2013 20:34:33
it has a piston pump with a 3[8 plug in front how hard is it to rebuild the hyd pump
WayneIA
07-20-2013 10:13:39
 Re: ford naa in reply to big farmer, 07-20-2013 08:41:10
Depends how far you want to go on a rebuild. Replacing the shaft seal and the check valves seats takes some know how and patience. Sounds as if your check valves springs and/or spring guide pins are the problem. Take the head off the pump and have a look see. Pump rebuild kits are available from several sources including this site has a $35.93 . Would give you a link if I was 60 years younger, which makes me computer illiterate
Greg1959
07-20-2013 10:19:39
 Re: ford naa in reply to WayneIA, 07-20-2013 10:13:39
WayneIA- HTH :D
http://www.yesterdaystractors.com/Ford-NAA_Hydraulic-Pump-Repair-Kit_CCPN600AB.html
WayneIA
07-20-2013 10:38:21
 Re: ford naa in reply to Greg1959, 07-20-2013 10:19:39
Thanks Greg
