Show Parts for Model:
Re: 9700 aircondition-blower problems
07-19-2013 11:12:13
Check to make sure that the fuse did not get hot and warp the element inside so as to lose contact. That has happened on our 9700 more than once. Usually means it is pulling too many amps (fan motor going bad)
07-19-2013 14:36:23
 Re: 9700 aircondition-blower problems in reply to mike2366, 07-19-2013 11:12:13
If the fan motor was pulling too many amps, the fuse should blow.
The reason the fuse holder melts is because the fuse contacts rust and/or corrode, creating resistance which creates heat, thus melting the solder on the ends of the fuse caps. The reason other fuses don't melt this way is because no other circuit in that fuse box draws that much current. Heat buildup because of resistance is in direct proportion to current flow.
I repair this by yanking the two wires from the back of the fuse box and connecting them to a 30-amp circuit breaker.
