Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 800 Parts Online
Re: 800 Front Axle Pivot
Billy NY
07-17-2013 10:06:04
I see that, looking at the spare/core, line bore situation, I was wondering what the trick to that was, using the pin to locate it, then tack the edges so they don't warp with heat, then stitch weld or enough to hold it, but not over do it so you can remove it again if ever needed.
Dean
07-17-2013 10:24:32
 Re: 800 Front Axle Pivot in reply to Billy NY, 07-17-2013 10:06:04
After drilling out the welds, I attached the plates using grade 8 bolts, nuts and washers.
I then installed the axle pin before tightening the bolts.
Only then did I weld the plates in place.
I left the bolts in place.
Worked well, but tolerances are close and it would be easy to end up with misaligned plates rendering pin installation impossible.
Dean
