Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 800 Parts Online
Re: 800 Front Axle Pivot
07-17-2013 09:49:25
I"ve repaired a couple of Ford front axle supports with good results using Pfeiffer"s repair plates.
You must take your time and make sure that things are properly aligned.
07-18-2013 10:09:06
 Re: 800 Front Axle Pivot in reply to Dean, 07-17-2013 09:49:25
Yes,alignment is critical.I had the repair piece welded in by a friend of mine who is an excellent welder.I installed the axel center section by itself supported on one end with a jack stand and the other end with my right hand.I turned the pin in fully with my left hand.I doubt the tractor left Dearborn that good!
Billy NY
07-17-2013 10:06:04
I see that, looking at the spare/core, line bore situation, I was wondering what the trick to that was, using the pin to locate it, then tack the edges so they don't warp with heat, then stitch weld or enough to hold it, but not over do it so you can remove it again if ever needed.
07-17-2013 10:24:32
 Re: 800 Front Axle Pivot in reply to Billy NY, 07-17-2013 10:06:04
After drilling out the welds, I attached the plates using grade 8 bolts, nuts and washers.
I then installed the axle pin before tightening the bolts.
Only then did I weld the plates in place.
I left the bolts in place.
Worked well, but tolerances are close and it would be easy to end up with misaligned plates rendering pin installation impossible.
