TractorLinks.com
Show Parts for Model:
Re: Anti Cavitation Treatment?
Larry NCKS
07-17-2013 03:46:55
I agree with Bern. This is not snake oil!
I bought a new tractor in 1976. Within a month or two of my purchase, this same model began being factory fitted with a coolant filter. My owner's manual didn't mention it, but upon asking service personnel at the dealership about the wisdom of it I decided it needed one. Since neither my selling dealer nor the company would do a retrofit; I went to a neighboring dealership, bought the kit and installed it myself.
Bern
07-17-2013 08:25:13
 Re: Anti Cavitation Treatment? in reply to Larry NCKS, 07-17-2013 03:46:55
Larry,
Which model came factory equipped with a coolant filter in 1976? Do you mean 1986 by chance?
Larry NCKS
07-17-2013 11:35:07
 Re: Anti Cavitation Treatment? in reply to Bern, 07-17-2013 08:25:13
Nope! 1976 IH 986 - by early 77 anyway.
Bern
07-17-2013 12:16:49
 Re: Anti Cavitation Treatment? in reply to Larry NCKS, 07-17-2013 11:35:07
OK, I thought you meant a Ford model. Ford didn't come out with coolant filter kits until the mid 80s.
Michaels Dad
07-17-2013 12:26:14
 Re: Anti Cavitation Treatment? in reply to Bern, 07-17-2013 12:16:49
I was just informed that cavitation is only a problem on sleeved motors.
True?
Bern
07-17-2013 15:46:50
 Re: Anti Cavitation Treatment? in reply to Michaels Dad, 07-17-2013 12:26:14
Nope. Happens on parent bore engines also.
Ford went to great lengths to reduce the possibility of cavitation erosion with the Genesis series blocks. If they never had a problem in the past, they would not have made the changes. You could pretty much count on any TW block made in the 1980s to pinhole within 5000 hours or less.
Check Break
07-17-2013 15:37:48
The Fords are parent bore, no sleeves.
Cavitation erosion is not limited to the cylinder walls and will occur anywhere there is coolant. The early blocks, 65 to mid 70-s, did not seem to suffer from erosion as much as those that followed. Not sure why. We always assumed a change in metallurgy.
JMOR
07-17-2013 15:46:28
 Re: Anti Cavitation Treatment? in reply to Check Break, 07-17-2013 15:37:48
I don't know precisely when it started, but those years sound reasonable for the beginning of thin wall castings in engine blocks, so maybe...............
RodInNS
07-17-2013 15:19:24
You've been informed incorrectly... or Ford has been lieing to us for ~30 years.
Rod
JMOR
07-17-2013 13:25:30
Quoting Removed, click Modern View to seeI have found articles that indicate that is "worse" on sleeved engines, worse on a thin wall cast/non-sleeved than on thick wall cast. Also, that it is almost never a problem except on diesels, primarily due to the vibratory spikes resulting from spike rise of high combustion pressures.
Some say Ford's 7.3 cast/non-sleeve is worse than 6.9, because with the overbore, walls are thinner. So, "only" is not a good word, here.
Tx Jim
07-17-2013 03:58:40
I agree coolant conditioner isn't snake oil. I also don't see how a 3 cyl engine is safe from cavitation.
RodInNS
07-17-2013 04:54:15
 Re: Anti Cavitation Treatment? in reply to Tx Jim, 07-17-2013 03:58:40
Plain and simple... they're not. I have a 3 cylinder 201 block around here somewhere that cavitated. They all need conditioner. I use FG DCA4.
Rod
Michaels Dad
07-17-2013 05:47:14
 Re: Anti Cavitation Treatment? in reply to RodInNS, 07-17-2013 04:54:15
It's not snake oil.
Back in the day we had 3 diesel powered firewater pumps at out plant.
Two of them developed severe damage from not being treated.
After rebuilds they were fitted with coolant filters with protection built in as well as a liquid that was added to the coolant. We were also to test the coolant mix once a month to monitor it's status.
At that time I was told this problem was peculiar to stationery diesels. Sounds like Mustang Equipment was wrong.
Now you've got me wondering about my 2 cylinder Kubota.
This post was edited by Michaels Dad at 05:50:06 07/17/13.
Sean in PA
07-17-2013 04:10:00
I don't think the 3 cylinder engines are safe from it. I know I've read of at least a few folks who had to have theirs sleeved because of it. I just think that the cylinder walls might be a little thicker than they were on the earlier 4 cylinders, so it might take longer for the damage to be noticed, plus they're newer so they haven't had as many years/hours of being worked hard on average as most of the earlier 4 cylinders have had, so again the damage hasn't caused as many leaks .... yet.
