Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 601 Parts Online
Re: Ford 601 1960 yr.
36 coupe
07-17-2013 01:31:20
601 manual says all mild EP 90 gear oil.
Keith Williams
07-17-2013 17:43:18
 Re: Ford 601 1960 yr. in reply to 36 coupe, 07-17-2013 01:31:20
He has the correct #. It is just not available anymore. It for sure is not EP 90. You are not correct 36 Coupe.
To original poster. I used UTF that meets 134D Spec, it works for me.
As stated by Tony Jacobs before, there is a Valvoline product that more closely matches the old spec. It is a little thicker than 134D. (but it sure is not 90 wt)
07-17-2013 23:44:24
 Re: Ford 601 1960 yr. in reply to Keith Williams, 07-17-2013 17:43:18
Hello Keith , Technically it is still available just could not ever figure out why they called mild ep 80 or 90 , as one number is an A(80 weight) and the other is B(90 weight). They are both Mineral oils 80 and 90 weight and that is what belongs in the N series tractors and that is what came in the 100 series tractors and 01 series tractors when new . I still use the Mineral oils in the N series tractors when I service them , hydraulic pump works much better with the thicker oil and lasts longer with the thicker oil . Tony
07-17-2013 05:53:49
hyds would be like pumping jelly in a cold area..
36 coupe
07-21-2013 04:50:09
 Re: Ford 601 1960 yr. in reply to soundguy, 07-17-2013 05:53:49
My 640 uses 90 weight in Maine and I work into January if deep snow holds off.I had no lift power in hot weather with 134.Changed to 90 and no more trouble.
07-17-2013 23:56:57
Hello Chris , He is in Texas . The Hydraulic pump will pump the proper 80 or 90 weight mineral oil here in New England just fine , I know it would not pump 80 or 90 weight gear oil because it was not designed to though , I never could get an answer why Ford listed it that way . Tony
07-18-2013 07:14:04
 Re: Ford 601 1960 yr. in reply to TONY JACOBS, 07-17-2013 23:56:57
that's why i don't reccomend 80-90 in the hyds.. because the average person is going to go to autozone and buy gear oil...
