Tim Crawford
New User
I have a 1954 Ford that replaced all the seals in the lift, drained the fluid cleaned everything put in new fluid and everything was working great. Ran it with box blade for 45 minutes then unhooked and put 2 bottom plow on. Went to field dropped the plow and it kept going down would not stop. Then was not able to lift the plow. If I take the implement off I am able to get the arms to lift. If I stand on the arms the lift arms will go up and down. I weight about 200 pounds. If I put the box blade or the plow on it will not lift. Can someone tell me what is possibly causing the problem.
