Yesterday's Tractor Co.
Shop Now View Cart
Order Ford NAA Parts Online
Re: Ford NAA will not lift implement
Tim Crawford
07-13-2013 17:28:18
I did have it in draft control. The tractor is on my hunting land so I don't have access to it at the moment but I was thinking it was the seal on the piston that may have broke or could it be the pressure relief valve?
07-13-2013 19:18:09
 Re: Ford NAA will not lift implement in reply to Tim Crawford, 07-13-2013 17:28:18
Could be either one. Only way to know for sure is to pull the inspection plate off the one with the dip stick
Tim Crawford
07-15-2013 18:15:37
 Re: Ford NAA will not lift implement in reply to old, 07-13-2013 19:18:09
I guess the only question I have is how likely it it that the pressure relief valve has failed. I have never was one up close and personal but what I have was for sale online for a Ford NAA looks to be nothing more than a piece of steel with several holes drilled in it.
07-15-2013 18:19:52
 Re: Ford NAA will not lift implement in reply to Tim Crawford, 07-15-2013 18:15:37
A good bit more to a relief valve hen that but you have to open one up to know that. If is a spring and plug sort of set up that opens when and if you get to high a pressure on the system as a safety. That pressure is around 2000PSI
Tim Crawford
07-20-2013 14:10:48
 Re: Ford NAA will not lift implement in reply to old, 07-15-2013 18:19:52
Well I have my answer as to what is wrong. My brother was able to stop at the hunting land, attached the box blade to the tractor and tried to lift it. Viewing through the fill hole he says it is spewing hydraulic fluid out the other side of the lift assembly. Sounds like a case of a blown gasket. Thanks to everyone who gave me advice on this issue.
