Yesterday's Tractor Co.
Shop Now View Cart
Order Ford NAA Parts Online
Re: Hard steering Jubilee revisited
07-13-2013 17:24:52
if the box has a core plug int he bottom.. yep.. you can nock it out.
at least a few boxes seem to NOT have the plug.
if no plug.. or if you are handy with a welder.. some 6013 and low amps and you can weld the face of the race and shrink it like the other poster said.
IO've done that plenty on top bearing races in those boxes
07-13-2013 18:45:29
 Re: Hard steering Jubilee revisited in reply to soundguy, 07-13-2013 17:24:52
Thank you. I do some welding so will try this. I don't have any 6013-only 7014, but I'm sure that will work.
07-13-2013 18:57:20
 Re: Hard steering Jubilee revisited in reply to Dr.Bert, 07-13-2013 18:45:29
i just use 6013 for low pen.
if no 6013.. then some fast freeze or stuff good for OOP would work. just use low amps.. dont want to weld the race to the housing.. :) just a lil bead around the face.. and lower in a bit where some thickness is. when she cools.. she will draw. some 'fall' rige out when inverted and tapped on a table after a few minutes.
