Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 600 Parts Online
Re: Ford 600 hydraulics Problem
Kurt-NEPA
07-13-2013 10:07:34
No O-ring on the control valve, its a metal on metal seal. If they leak it is minor and results in hiccups, not a total failure of the lift.
RMV
07-13-2013 10:27:25
 Re: Ford 600 hydraulics Problem in reply to Kurt-NEPA, 07-13-2013 10:07:34
Thanks Kurt for helping me.
I know the pump is working, but why can't I see any flow?
Its flowing somewhere because the guage on the bleeder on the pump is zero
JMOR
07-13-2013 11:46:02
 Re: Ford 600 hydraulics Problem in reply to RMV, 07-13-2013 10:27:25
Quoting Removed, click Modern View to seeYou have a 3000# ?? gauge on pump bleeder port and if valving is unloading via backpressure valve, that sets system pressure to about 40# and you can't see that small pressure on your high pressure gauge. Where is the flow? Out the unloader/backpressure valve.
RMV
07-13-2013 12:40:04
 Re: Ford 600 hydraulics Problem in reply to JMOR, 07-13-2013 11:46:02
When I free up the unloading valve I didn't change the o-ring could that be the problem?
JMOR
07-13-2013 12:44:20
 Re: Ford 600 hydraulics Problem in reply to RMV, 07-13-2013 12:40:04
RMV said: (quoted from post at 15:40:04 07/13/13) When I free up the unloading valve I didn't change the o-ring
Not really possible to say. It has to befree enough to move with only low pressure (~40#) applied but yet tight enough to seal, so???
But remember too, that control valve must be in correct position (think linkage adjustment) to control flow into & out of unloader valve in order to make it move. Not a solo act.
This post was edited by JMOR at 12:51:27 07/13/13.
RMV
07-13-2013 13:12:20
 Re: Ford 600 hydraulics Problem in reply to JMOR, 07-13-2013 12:44:20
Ok I am going to order the manual.
The control arm that you move to make the 3point go up and down moves free until it gets close to the last part of the lifting end and has a little resistance, is this normal?
JMOR
07-13-2013 13:35:11
 Re: Ford 600 hydraulics Problem in reply to RMV, 07-13-2013 13:12:20
Quoting Removed, click Modern View to seeAs best I remember & thinking, that depends on how high the arms are and also whether in Draft mode or Position mode. But it at least isn't uniform over the full range, so for today, call it normal. :)
