TractorLinks.com
Order Ford 600 Parts Online
Re: Ford 600 hydraulics Problem
Kurt-NEPA
07-13-2013 07:26:11
Bad linkage or badly worn or broken cam follower pin could cause your problem. Other possibilities too.
When you look in the dip stick cover hole, can you see the linkage attached to the control valve? If yes, get someone to move the touch control lever while you watch. Does the control valve move in and out. Tractor does not need to be running to check this.
Post back if you don't understand the terms I used.
Another thought, make sure you are in position control mode
