TractorLinks.com
Show Parts for Model:
Re: tractor won't start
Royse
07-09-2013 21:04:16
As I said before, not 100% sure, but I believe your tractor has a resistor
wire to the coil (i.e. ballast resistor) that is bypassed when starting.
One of the guy more familiar with the 1965+ models could say for sure.
Tony walters
07-10-2013 08:00:41
 Re: tractor won't start in reply to Royse, 07-09-2013 21:04:16
,,Joe 201 you can run a 12 ga wire to battery to coil,,to get you by for now,,it will work ok,,you basic by passing the key ignition as you have said the key will start it,,the 12 ga wire will keep it running ,,Be sure to add a way to stop the motor,,shut off switch in line will work fine,,i did this to my 1968 ford 2000 gas tractor,,,
Tony Walters
07-10-2013 08:18:52
 Re: tractor won't start in reply to Tony walters, 07-10-2013 08:00:41
Joe 201 i ran the the icr13 ignition resistor in line with wire,,you dont have to use that heavy of wire as i did for testing,,
