Bill Radford
To all the guys that posted re hydraulic pump
noise:
After work I went out and pulled the pump.
The good news:
the cam gear is solid and straight. No appreciable
wear on the gear. When I start the engine there is
nothing but the normal valve train/timing gear
noise
More good news: the pistons underneath the wobble
plate all feel good with good spring action and
suction. I think that the piston end of the pump
is a- ok.
Bad news:
When I look at the pump gear, it rotates with a
wobble. The gear is supposed to turn straight but
it appears that it is crooked in the housing. The
wobble shaft has around 2 mm of thrust from inside
to outside. I think the bearing is bad and the
shaft is crooked.
Think I'll replace the bearing and check the shaft
and gear.May wind up replacing gear, wobble shaft
and bearing. Much better than it could have been..
Thanks again
Bill
noise:
The good news:
noise
is a- ok.
Bad news:
shaft is crooked.
Thanks again
Bill
