Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 961 starting system
Freewheelin'
07-08-2013 21:39:30
If the system is a 12 volt then the small wire to the coil makes sense because it would kick up the normal 6 volts from the coil to 12 volts while the engine is starting. The old Ford cars used that type of solenoid but with the starter switch in the ignition switch. I assume that some of the Ford tractors with 12 volt systems would use that design but then I don"t know if they still used the push button starter switch nor how it would be wired.
soundguy
07-09-2013 11:54:43
 Re: 961 starting system in reply to Freewheelin', 07-08-2013 21:39:30
pre 65 used the 4 terminal solenoid and no bypass.
post 65 used a resistor wire, 6v coil and a bypass line to the coil key switch start.. no thumb button.. but did have a NS onthe range shifter
