TractorLinks.com
Show Parts for Model:
Re: tractor won't start
Hobo,NC
07-08-2013 19:04:29
Before I would assume its bad wiring are the build in resistor wiring I would check the voltage at the ignition switch that powers up the ignition in the run position... I am thinking bad switch are no power to the switch...
If I were unsure and did not have time to figure it out as you do I would jump the coil directly off the battery add a ICR13 ignition resistor in the circuit off the jumper to the coil and run it till you get the hay up...
Are get a NAPA IC14SB coil and straight wire it for now no resistor needed..
In a nut shell you have 99% confirmed your issue is in the run/on circuit of the ignition switch are associated wiring...
Another reason why I like voltmeters it will tell the story no guessing needed...
