TractorLinks.com
Order Ford 4610 Parts Online
Re: Ford 4610 cut off and won't start. Help
david1
07-08-2013 19:03:12
I got 2 of the injectors cracked open and bled but I ran the battery low and have to wait to let it charge up before I try in the morning. It was blowing bubbles at the injector when I had them cracked open. having a hard time get to the 3 rd one because its got a loader on it and the battery try doesn't want to swing very far with out hitting it. Not sure where to bleed the injector pump.
Shetland Sheepdog
07-08-2013 19:12:16
 Re: Ford 4610 cut off and won't start. Help in reply to david1, 07-08-2013 19:03:12
Don't worry about bleeding the pump or 3rd injector! Crank it over with the 2 injector lines loosened until you get fuel without bubbles at the injectors, then tighten the lines and it will start!
BTDT many times, Dave
Tx Jim
07-09-2013 04:39:52
 Re: Ford 4610 cut off and won't start. Help in reply to Shetland Sheepdog, 07-08-2013 19:12:16
IF it has just the straight 2X4 trans with no hyd reverser/ hyd 2 speed I'd run a chain under the bucket(if bucket is on ground) and tow itto start the engine. I once owned a 3000 with a non working fuel gauge that my employee ran out of fuel several times that I could bleed it until I was blue in the face & it wouldn't start BUT pull it 5(five) ft and it would start.
This post was edited by Tx Jim at 04:41:02 07/09/13.
