Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 4610 Parts Online
Re: Ford 4610 cut off and won't start. Help
07-08-2013 18:53:34
White smoke is a good thing. That makes it sound like you have successfully bled the filter. Most likely now you are short on RPMs you need to spin it over pretty quickly for it to generate the compression to fire. So, charge the battery good and if possible boost with cables or your booster pack. It should start then.
07-08-2013 19:03:12
 Re: Ford 4610 cut off and won't start. Help in reply to showcrop, 07-08-2013 18:53:34
I got 2 of the injectors cracked open and bled but I ran the battery low and have to wait to let it charge up before I try in the morning. It was blowing bubbles at the injector when I had them cracked open. having a hard time get to the 3 rd one because its got a loader on it and the battery try doesn't want to swing very far with out hitting it. Not sure where to bleed the injector pump.
Shetland Sheepdog
07-08-2013 19:12:16
 Re: Ford 4610 cut off and won't start. Help in reply to david1, 07-08-2013 19:03:12
Don't worry about bleeding the pump or 3rd injector! Crank it over with the 2 injector lines loosened until you get fuel without bubbles at the injectors, then tighten the lines and it will start!
BTDT many times, Dave
Tx Jim
07-09-2013 04:39:52
 Re: Ford 4610 cut off and won't start. Help in reply to Shetland Sheepdog, 07-08-2013 19:12:16
IF it has just the straight 2X4 trans with no hyd reverser/ hyd 2 speed I'd run a chain under the bucket(if bucket is on ground) and tow itto start the engine. I once owned a 3000 with a non working fuel gauge that my employee ran out of fuel several times that I could bleed it until I was blue in the face & it wouldn't start BUT pull it 5(five) ft and it would start.
This post was edited by Tx Jim at 04:41:02 07/09/13.
