TractorLinks.com
Order Ford NAA Parts Online
Re: Foamy trans oil in NAA
petertay
07-08-2013 15:24:54
SoundGuy, I found where you answered my fluid questions on another forum as you discussed the various fluids for the various purposes. Thanks.
But I do have a further question about the FEL return line. You said, "you can tie the 3pt arms down and come out of that plug on e naa blank cover to feed an OC valve, and then return to the tank via the fill cap."
Do you mean tap a hole in the wide cap where fluid is added? Sounds inconvenient when fluid is being added, or did I misunderstand?
Thanks
soundguy
07-09-2013 06:27:30
 Re: Foamy trans oil in NAA in reply to petertay, 07-08-2013 15:24:54
return lines are low pressure.
most guys that are faking out hyds tieing the 3pt down just simply take a 90' elbow fitting with pipe thread on one side and a hose barb on the other. they drill the hyd fill cap and tap for pipe threads.. screw the cap on, and then screw the fititng in till it lines up good for the return line, then just push the return line onto the barb. to add fluid.. all ya gott do is slip hose off and remove cap.
another option is to plumb that fitting into the cover where the hyds dipstick is... etc
