Mark Hager
New User
My Hydraulic Pump stopped working (and my tractor was overheating). I took off the Hyd pump and the teeth on the Camshaft Drive Gear inside the tractor housing were all chipped off - metal shavings around the pump drive gear and the tractor drive gear. I assume what happened is my pump failed, locked up, and the teeth chipped off as the tractor drive gears moved, and the pump gears did not. Plan to replace or get my Hyd pump replaced. Here is my question - how hard is it to replace the Camshaft Drive Gear inside the tractor - doesn't look like a weekend mechanic kind of job. HELP!
