Ford 1900 Diesel
Anonymous-0
I need a few parts for my buddies 1900. I'm trying to find a dealer online and not having much luck. Does anyone know of a good dealer that carries 1900 parts. I need a new ignition switch and the lower radiator hose.
Thanks in advance
New Holland parts site shows the ignition key switch as part number SBA385200331. It is listed as in stock on partspring.com and external_link, and should be available at any New Holland dealer.
There appears to be 2 different part numbers for the lower radiator hose depending on the manufacturing date of the tractor. For tractors made from 1/1/79-9/30/79 it is a 12" long hose, part number SBA310160150, and for tractors made on or after 10/1/79 it is a 13" long hose, part number SBA310160350. partspring.com has both in stock, and external_link has the later 12" hose in stock, and as with the key switch , you should be able to get them from any new Holland dealer.
have you checked CNH? the switch almost assuredly is available. i'd be surprised if the hose wasn't as well.
