Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Ford 641 hyrdaulic pump problem
WayneIA
07-07-2013 16:53:45
You mention blowing the gasket on the hyd pump. Take the pump apart and take the main body to a machine shop and have it planed like shaving the surface of a cylinder head
The noises in the pump are usually one of three things. A loose drive gear on the pump,(possible) a loose gear on the cam that drives the hyd pump ( not likely) or bad timing gears on the front of the engine. (Probably)
Hal/ Eastern WA
07-08-2013 13:49:49
 Re: Ford 641 hyrdaulic pump problem in reply to WayneIA, 07-07-2013 16:53:45
That is probably a good idea, and I might try it if my homemade gasket also fails. When I made the new gasket, I left more "meat" in the areas where the commercial gaskets would fail. The polycarbonate SHOULD be a lot stronger than the paper gasket it replaces.
So far it seems to be working fine. If the polycarbonate gasket fails, I might try making one out of soft copper sheet.
I have wondered why the gaskets kept failing. Maybe there has been erosion in that spot on the pump body, although I could not see or feel anything that worried me. Some years ago, I replaced the hydraulic relief valve with one from the aftermarket. I am wondering if that valve has stuck and the system is getting over pressurized. Then next time I drain my hydraulic oil I think I will put the original relief valve back in, assuming I can find it. When I changed the relief valve, it did not change the symptoms I was trying to fix.
Thanks for your input!
Copyright © 1997-2015 Yesterday's Tractor Co.
