TractorLinks.com
Order Ford 800 Parts Online
Re: ford 800
gtkeith
07-07-2013 13:20:37
someone put longer bolts in the 2 bottom holes below the pto shaft that holds the hitch bracket and broke the casting so I am trying to decide the easiest way to get inside and make a repair any suggestions appreciated
John in La
07-07-2013 13:45:00
 Re: ford 800 in reply to gtkeith, 07-07-2013 13:20:37
I think the 2 bottom holes are ears on the center housing rather than threw holes. (But I may be wrong)
If I am right getting to the inside will do you no good.
Or is the casting broken so much it is leaking oil???????
gtkeith
07-07-2013 13:56:14
 Re: ford 800 in reply to John in La, 07-07-2013 13:45:00
yes one of the ears broke and one is leaking because it broke the casting inside
thanks
John in La
07-07-2013 14:07:26
 Re: ford 800 in reply to gtkeith, 07-07-2013 13:56:14
In that case I am afraid your real question is.....
How do I remove the center housing.
Cause to try and weld a crack in that cast case you gona need to get it real clean.
gtkeith
07-07-2013 14:15:37
 Re: ford 800 in reply to John in La, 07-07-2013 14:07:26
Yes I think that is what I have to do
Thanks
