900 RC double clutch
No, mine works just fine.
Have you done some work to it, or are you trying to?
There is a very specific adjustment procedure if you are.
No not doing any work on it just bought it it looks like a new pressure plate it would grind gears one day so i pulled bottom plate on trans down and two fingers are hung up sprayed them with liquid wrench going to try to pry them out
Has this tractor been setting? Perhaps the clutch is stuck! When peering through the square hole at the bottom, you should almost see three fingers on one plane and three fingers " bent towards the engine" in alternating positions. Highly unlikely the fingers are hung up on a double clutch, unless it has sat for years.
