TractorLinks.com
Order Ford 2000 Parts Online
Re: 2000 pto lever
Ultradog MN
07-06-2013 18:26:36
We need more info to be much help.
Do you have a pre 1965 4 cylinder 2000 or a post 1965 4 cylinder 2000?
If a 3 cyl which tranny do you have - single stick 4 speed or a twin stick 6 or 8 speed?
jim wieringa
07-06-2013 19:46:54
 Re: 2000 pto lever in reply to Ultradog MN, 07-06-2013 18:26:36
the tractor is a 1966 3cyl gas with 6 speed twin stick.
Ultradog MN
07-07-2013 05:10:36
 Re: 2000 pto lever in reply to jim wieringa, 07-06-2013 19:46:54
Check the rivit as Soundguy says. The handle might be slipping on the shaft.
Otherwise it's easy to remove the 3 bolts and pull the handle/shifter out and inspect the fork, sliding collar etc. They are pretty simple.
You might have to drain the oil in the rear end down to see.
