860 power beyond?
I have what I believe is sometimes called 'power beyond' valve that was used to run a liguid fertilizer slinger. I would like to be able to add plug in hyd hoses. Do you loose 3 pt lift when you use this valve type? What does this site sell that would adapt it for hoses to run a hyd.cylinder on disk and sickle mower cylinder?
I tried to add a picture but I can not figure it out. I tried to use photobucket but I can't figure it out. I posted a pic of this in tractor photos though if you want to look there to see what I have. Thanks.
on my small screen on my phone.. that looks like a simple diverter valve.
it's SA and uses the 3pt control. when engaged. 3pt is dead.
yuo can use that to run a OC style valve. or get a real PB plate that sandwiches under it that will run a OC PB type valve, and your 3pt will work normal unless a spool is engaged at that particular moment
