Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 1310 wants to start but wont
sixbales
07-05-2013 04:59:35
The white smoke is unburned fuel. The black crap out the exhaust is "diesel slobbering" - you are going to see a lot of slobbering until you get it running and work it hard.
Most likely the rings have unseated, and the engine has lost some compression.
I would pull the injectors and have them checked at a diesel shop.
While the injectors are out, I would put a couple tablespoons of ATF in each cylinder to try to loosen up the rings.
Ted E Bear
07-05-2013 12:46:02
 Re: 1310 wants to start but wont in reply to sixbales, 07-05-2013 04:59:35
sixbales, the smoke issue is kinda what I figured,i will go and most likely get the tractor and bring it home and tear it apart and work it over, I don't understand why sometimes it knocks loudly then stops when u crank it and pull it, but im not to concerned at this point cause my diesel generator did that when it wouldn't start, im kinda thinking that there is a timing issue with this tractor, I also think that there was more issues with it than what was told to my friend when he bought it, (it wasn't running) I would have not got it not running myself,
Copyright © 1997-2015 Yesterday's Tractor Co.
