TractorLinks.com
Show Parts for Model:
Re: 1310 wants to start but wont
sixbales
07-03-2013 12:42:54
Are you getting fuel to the injectors when you bleed at the injectors?
Has this tractor been down for an extended period (6-8 months or more)? It might be that the rings have unseated to some degree, and you"ve lost some compression. I would tow start it and keep on pulling it (safely) until it starts and runs on its own.
Ted E Bear
07-03-2013 18:55:01
 Re: 1310 wants to start but wont in reply to sixbales, 07-03-2013 12:42:54
sixbales, yes its been sitting with head off covered in corner of shop for almost 2 years,
and it seems like im not getting enough fuel at all, I let it set last nite and went back at it again today, with no luck,i took the lines from the fuel pump to injectors off and just a couple drips of fuel came out of the lines, I did take the pump out to clean it and its pretty sticky, so im cleaning it up, then I will re install and try again, so you think I should be pulling it till it runs on its own??
sixbales
07-04-2013 03:35:59
 Re: 1310 wants to start but wont in reply to Ted E Bear, 07-03-2013 18:55:01
Ted,
You have to be satisfied that you have fuel to the injectors, and the system is properly bled.
Injection pumps produce a very small amount of fuel/high pressure. Volume at the injectors can be deceiving.
Have you replaced the old fuel? Does it run with starting fluid?
Are you getting good cranking speed with the battery & starter? Low cranking speed can be a problem, especially if compression is down a bit due to the long period of inactivity. Tow-starting will improve this.
Ted E Bear
07-04-2013 19:35:55
 Re: 1310 wants to start but wont in reply to sixbales, 07-04-2013 03:35:59
well, bad news! that tractor is not running yet, we are getting fuel, we tried to pull start it and it did run but for 2 minutes with no throttle control, it was blowing a bunch of crap out so we kept pulling it around, we never got it to run again, it was billowing white smoke really bad and pushing oil out the ex. valves, not a good sign for a reman head!there is oil spray all over the owner and the side of the tractor, I guess the good news here is that we are getting fuel and the motor isn't locked up, im stumped even more now
sixbales
07-05-2013 04:34:29
 Re: 1310 wants to start but wont in reply to Ted E Bear, 07-04-2013 19:35:55
The white smoke is unburned fuel.
Most likely the rings have unseated, and the engine has lost some compression.
I would pull the injectors and have them checked at a diesel shop.
While the injectors are out, I would put a couple tablespoons of ATF in each cylinder to try to loosen up the rings.
Ted E Bear
07-04-2013 09:08:24
sixbales, I am going to re assemble everything today and yes, we drained the old fuel, we will try pulling it today and I will report back, thanks
