TractorLinks.com
Order Ford 2000 Parts Online
Re: Ford 3000 or 2000
Sean in PA
07-02-2013 17:05:43
Sounds like some mixes and matches definitely. All that you know from those stamped numbers on the transmission is what the tractor was that left the factory with that transmission installed in it.
The numbers on the transmission claim that it's got a gas engine but it really has a diesel, then either the
engine or the transmission was replaced at some point.
Since the rear axle has round trumpets, that says 2000, but the draft spring has the housing on it, which says 3000, so that top cover was not on that axle originally.
Since it's a diesel, what type of injector pump does it have? If it's got the Simms in line pump, then the engine's from a 3000, but if it has the CAV rotary pump it could from either a 2000 or a 3000.
Get the date codes off of all of the components and compare to see if you can reach a majority consensus.
