Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 3400 Parts Online
Re: tires for a 3400
07-02-2013 15:50:53
The 14.9-24 was generally used on the LCG tractors and had a different reduction ratio to compensate for use of the smaller tire. If you change to a 28" tire you'll probably find the tractor to be quite a bit faster. That may or may not be a problem to you...
The tractor itself would probably be better with the 28" tires provided the axle reduction is appropriate.
I think you'll also find the front spindles are shorter than standard on your tractor... so if you change to 28's it's not going to sit level.
07-02-2013 17:01:31
 Re: tires for a 3400 in reply to RodInNS, 07-02-2013 15:50:53
Rod...I was kind of worried about the ground speed, the tractor has the 6-4 tranny so I"m limited on the slow side. I don"t do any tilling but i do some gravel grading and like to go real slow for that. I just can"t get past the way the 28s look, they fill the fenders up real nice. I have 7.5s on the front and didn"t notice if the tractor sat too far out of level or not. Guess i can just put the 28s on and run for awhile and see how I like it.Thanks for the input...Dan
07-02-2013 16:31:37
OMG.. 14.9-28 are HUGE :)
I have a rowcrop ( 950 ) i put a set of 14.9-28 on. big difference from 11.2-28 which i kinda feel is close to rolling circumference to them 14.9-24
here's a side by side comparison. :)
07-02-2013 17:07:16
 Re: tires for a 3400 in reply to soundguy, 07-02-2013 16:31:37
SG...yea the 28s are big, this set I got came off a 8n I bought awile about looking silly...went about sixty in reverse too. Dan
07-02-2013 17:35:38
 Re: tires for a 3400 in reply to BigDanT, 07-02-2013 17:07:16
i imagine!
14.9 is 3 sizes up from what an N was designed for. 11.2, 12,4, 13.6 14.9 etc.
