Phil Eastman
Thanks to all who answered my starter button problem. I am having a problem now with getting diesel fuel out of the injector pump. To recap: 4 cylinder diesel that has not run in awhile. Have done all the preliminaries to get it ready to run.
Finally found the preheater switch and the starter switch. Have a new 980 cca battery. I have bled lines from the filter and have good fuel flow to the pump. Took the injector line loose closest to the pump but no fuel. I gave a short burst of starting fluid and it ran about 2 seconds. I am of the conclusion the injector pump is either bad or stuck. Any suggestions on what I should try besides another injector pump. Thanks for your help.
