Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 800 Parts Online
Re: Ford 800
Sean in PA
07-02-2013 10:39:31
Stand on the left side of the tractor and place your left hand on the starter and your right hand on the clutch pedal, and right in front of your face should be the battery tray. Just below the battery tray there should be a flat spot that faces up and there should be 2 numbers stamped into that flat spot. The first one should be the model number and the second one should be the serial number.
Post those numbers back here and we can tell you what you've got.
800 is the series, and they were made from 1955 through 1957. The individual model would be 820, 830, 840, 850, or 860. The second digit tells you what options it had in terms of transmission and PTO and whether it had a 3 point lift or not.
Jim Isler
07-02-2013 13:20:12
 Re: Ford 800 in reply to Sean in PA, 07-02-2013 10:39:31
Got thru the dirt. Model # is clear: 861 Number below it (serial #?) is 7560 with an embossed mark either side of the 7560.
