Anonymous-0
I have copied and read the article "step by step 12-volt conversion" as it appears on this web site. Although my tractor is not a Farmall--most of the guidance is approprite for my Ford 600. I have replaced the 6v coil for a 12v coil so a ballast resistor is not required. However my problem (which is not mentioned at all in the article)is that the Ford 600 is made with a 6v starter solenoid. I have replaced mine with a 12 v solonoid. However there is absolutely no guidance as to how the solonoid is wired into the system. As this is the only item holding up my conversion i would appreciate some instruction as to where the wires to and from the solonoid should go. Thank you.
