9N - NAA wheel lug pattern
Assuming you don't have an early 9N with 32 in rims, they're both 28 inch.
The outer 6 bolts that hold the rims to the centers are the same.
The centers are obviously not the same.
The width of the rims and tires are different, but they should fit temporarily.
And I guess I shouldn't have assumed rear wheels!
The front rims on the 9N were a large diameter center-less rim,
with a 5 bolt pattern, not at all like the later 8N/NAA 6 bolt rims.
But, someone could have put 8N hubs on your 9N, so if they look
close and have 6 lugs it might be worth a try.
Just about any standard 6 bolt implement rim fits them, and I think
most 3/4 ton Chevy pickup rims.
Not sure how well it will show up, but this is my NAA with truck tires
on the front.
