TractorLinks.com
Order Ford 4000 Parts Online
Re: Foor 4000 Injector pump
Phil Eastman
07-01-2013 19:06:28
Thanks. I have not even looked for that. I will look for it tomorrow.
Texas!
07-02-2013 11:05:56
 Re: Foor 4000 Injector pump in reply to Phil Eastman, 07-01-2013 19:06:28
There"s no oil in the RoosaMaster pump nor is there a separate shutoff lever. The shutoff is part of the throttle- push the throttle lever all the way up to shut off the fuel. There is a metering valve in the pump that sometimes gets stuck in the shutoff position.
I"d keep giving the engine short shots of ether to keep it running and see if the pump will start working.
Phil Eastman
07-04-2013 17:51:59
 Re: Foor 4000 Injector pump in reply to Texas!, 07-02-2013 11:05:56
Thanks Texas. I gave three short shots of starter fluid and the engine took right off on its own. It has started three times since with no help so the injector pump needed the speed to prime and start pumping. Now another problem. How do I get the SOS transmission locked again so I can freewheel the tractor to get it off the trailer. I have rocked the tractor while turning the transmission lock but it wont lock. Please any assistance is welcome.
Phil Eastman
07-02-2013 20:41:41
Thanks for all the replies. I figured the shutoff was on the throttle since there was no other lever going to the pump. I have tried squirting gasoline to start it but that did nothing. I will try the starting fluid again although I hate to use it. Thanks.
