Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: SOS Help!
Larry NCKS
06-11-2013 07:08:43
You need to follow procedure to a T. I'm guessing with Greg NE that you did not take the shifter housing loose from the dash so that whole assembly would move up and away from the transmission????? If so, did you shift the selector to 10th and possibly force the connector down where it came apart as has also been suggested?
RICK IN GA
06-11-2013 08:17:13
 Re: SOS Help! in reply to Larry NCKS, 06-11-2013 07:08:43
I did have the dash panel that the shift lever is attached to removed from the tractor as an assembly. I must admit that I expected to be able to remove the shift cable from the shift lever at first to remove the entire assembly from the tractor but there is no way for that shift lever and housing to pass through the dash panel due to the cable and the size of the shift lever housing. This is one of those designs that surprised the heck out of me.
showcrop
06-11-2013 08:57:08
 Re: SOS Help! in reply to RICK IN GA, 06-11-2013 08:17:13
Which is why when in tenth gear it comes apart and the end pulls through the dash.
