TractorLinks.com
Show Parts for Model:
Re: no power, miss, diesel in crankcase
Brian Allen
06-10-2013 20:05:14
Alstractor
A little more information always helps! It sounds like it is not getting enough fuel.
Checking to make sure you have good fuel flow to the fuel pump is the first thing to find out!
Has the fuel tank, shutoff valve and screen been cleaned lately? Fuel filter(s) been serviced?
Brian
alstractor
06-11-2013 05:36:23
 Re: no power, miss, diesel in crankcase in reply to Brian Allen, 06-10-2013 20:05:14
seems to fill crankcase even while sitting if i dont turn off fuel, when running i think the pump pressure is leaking down thru front pump seal and not feeding all the injectors, is this possible?
RodInNS
06-11-2013 13:46:50
 Re: no power, miss, diesel in crankcase in reply to alstractor, 06-11-2013 05:36:23
Yes, that is possible. Very possible... However, do a drop test on the injectors first to eliminate that before you move to the umbrella seal on the pump shaft.
Rod
