2610 clutch
jp1977
New User
I have a 2610 tractor that the clutch is slipping on is the flywheel usually resurfaced when disc and pressure plate are replaced?
If it's grooved or worn at all, resurface it. If it's been heat blued badly... resurface it. If it looks good without micro cracking too bad... run it. Just make sure you replace the pressure plate with the clutch.
You should also probably replace the engine rear seal, rear core plugs in the water jacket, the pilot and release bearings and the front input shaft seals on the transmission...
Rod
