scrappypappy
New User
First off thanks SoundGuy for getting me to the right forum.
Might be a real dumb question but here goes. Can I replace main and connecting rod bearings in place? I mean without pulling the head, pistons, and crank?
If so, does anyone have a step by step process after I drain the oil and drop the pan?
Why do I want to change them? I have no oil pressure and some slight noise in the low end. I put a new guage on the tractor but still no oil pressure but when I pull the tubing off the gauge oil squirts out pretty good. Can a pump be bad and still put out oil pressure? The engine don"t smoke, don"t use, or lose oil, just no pressure
Thank you
Thank you
