Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 841 Parts Online
Re: 841 won't start fuel injector?
06-06-2013 07:55:39
My next question would probably be what is the fuel line coming out of the left side of the injector? It goes to a tee on the engine block then back up to the fuel tank. You can see this tee behind the pump in this other picture. I am sure you guys know what I am talking about without the picture anyways.
06-06-2013 08:11:11
 Re: 841 won't start fuel injector? in reply to canadianragweed, 06-06-2013 07:55:39
Did you leave the throttle all the way up in the "engine shutoff" position? If so your metering valve in the pump may be stuck in the closed position. This happened to me once on my 861D and I posted here about the problem. Zane immediately clued me in on the metering valve. On the aft end of the pump there is a cover that is held on with 3 screws. The metering valve is under that cover. I don't have any photos to show where but if you pull that cover off you can grab the metering valve with needle nose pliers and loosen it. I now always pull my throttle half-way down after the engine dies.
06-06-2013 08:16:30
 Re: 841 won't start fuel injector? in reply to Texas!, 06-06-2013 08:11:11
Yes I did leave it up let me go try and look at what you are saying and I will report back thank you.
