Value of pre 65 power adjust wheels and centers
SStra
Can any one tell me the value of a set of pre 65 power adjust centers and wheels? These appear to be sound but still need cleaned up.
Also can I run a set of wheel spacers on the inside of these to kick the wheels out so I can run the power adjust all the way in, and hang a set of large pie weights.
This is a parade tractor not stress on axles.
________
Also I have pictures, but can not make the modern view accept the message if i post the picture.
Get the following error .... but I can not seem to get a email to support either. Would take and any advice you have on that as well.
Thanks
The account being used was created too recently or inactive for too long to permit the use of bbcode images or links, please contact us by email to supportATytmag.com, and we can fix this for you right away. This restriction is not intended to apply to any real YT user.
Not sure of value but you can and should use the spacers that were OEM equipment with PA rims to prevent interference betweent the tires and fenders.
Dean
I have the factory wheel spacers. You can run them with power adjust rims. Pa rims we usually sell a good pair for 300.00 wheel spacers 125.00
4 in wheel spacers were standard only on 600/01 series and 800/01s with power adjusted wheels. They were not necessary or used on the row crop tractors, were the PAW was standard equipment.
