TractorLinks.com
Show Parts for Model:
Re: 961 starter question
soundguy
06-05-2013 05:19:53
the drive normally lives at the end of the shaft , the end far away from the starter. it sucks in toward the starter to engage,. when the engine starts and overspeeds the starter, the drive is unlocked to fling back out to the end of the shaft.
if yours is engaged.. you can overspeed it on a wire wheel on a bench grinder usually.
note.. the shaft must be squaky clean.. no rust.. no wet lubes like oil or grease to provide drag friction. dry lubes like silicone spray may be acceptable. also.. is the bushings are worn, or the shaft is bent.. it will cause side loads and other issues.
Freewheelin
06-05-2013 19:34:41
 Re: 961 starter question in reply to soundguy, 06-05-2013 05:19:53
I disassembled the drive unit, polished the plungers, and cleaned the holes. Used a piece of shim stock to keep the plunger recessed during assembly. Not the best design in the world. I noticed that one of the springs was slightly smaller than the other. Is that normal? I put it in the plunger that locks the drive. How do you bench test these things?
soundguy
06-06-2013 06:29:19
 Re: 961 starter question in reply to Freewheelin, 06-05-2013 19:34:41
spin the starter up see if it engages. then put it on the wire wheel to spin it back out.
