Freewheelin
New User
I"m working on my friends 961 Ford starter. Not familiar with Ford starters so would appreciate some help. The drive only moves back about 1/4 inches from full engagement. I disassembled the unit and found that there two small spring loaded plungers, one of which is designed to catch in a notch that prevents the drive from fully retracting. I can't understand how the plunger can be pulled back into the recess except perhaps by centrifugal force. So after I reassembled it, I wrapped a shoe string around the gear and pulled it hard as I could but the unit still wouldn't fully retract. Both the plungers and the springs looked to be OK. I"m thinking that maybe the plunger and the hole it travels in need to be polished. Am I on the right track?
