TractorLinks.com
Order Ford 2000 Parts Online
Re: 2000 hydraulics want work need help bad
JMOR
06-04-2013 05:34:43
Quoting Removed, click Modern View to seeWilly, you won't see 2000# unless lifting a very heavy load, BUT you should see (feel in your case) about 40#, as this is the relief point of the back pressure valve which is where all the flow passes when not lifting ("hold posn", "lower"), when unloader valve is in "unload" position. So, in my opinion, unless you "feel" somewhere around 40#, your pump isn't pumping. Could be bad pump, air leak somewhere on suction side, or seal leaking air in pump....
