I went ahead and purchased a rebuilt pump and I
can not get it to prime and it does flow out a
little oil and I can put my thumb on the plug hole
and it does not build up enough pressure to push
my thumb off,replaced relief valve checked for
leaks checked backpressure valve and I cant get it
to work,put air pressure through filler plug and
it makes the oil come out better at the pump but
still want build up any pressure.Is there anything
else I can do before I send pump back? I think the
pump is good sounds like it has good suction when
turning it by hand. Thanks for any help!!!
