I have recently acquired a 1959 Workmaster 641. The battery that was installed (and still is) is clearly a 6V battery. However the system is a negative ground.
I thought the 6V systems are positive ground and the 12V systems are negative ground?
Where there negative ground systems? And how would I check to see if this tractor is supposed to be 12V? Numbers on the generator or voltage regulator?
Help is appreciated!
Bill
Bill
