Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 600 Parts Online
Re: 3600 overhaul.
Ultradog MN
06-03-2013 14:04:46
I have done both - reused the oil pump and replaced it with a new one. Ford used to sell a rebuild kit for those pumps. Maybe CNH still does. Don't know how a kit compares with a whole new aftermarket pump. Aftermarket pump can be had for under a C note. You could just assemble the engine and add a temporary oil pressure gauge and check the pressure. Should read around 60-70 lbs.
I'm not sure what you are asking about the pistons. If you are wanting to rering the 3600 pistons and install them into the 3000 block then I would say it depends on how worn they are. Mic them up and go from there.
All internals from both engines will interchange so no problems there. I wouldn't worry about reusing them.
Ask a local clutch rebuilder about cost. If the pto clutch is slipping then a new disc is in order but those require about a $100 disc and the setup jig to install it.
A complete new double clutch with both new discs, pressure plate, throw out bearing, pilot bearing and plastic alignment tool can be had from this site for about $450. You will need your spline count to order one.
