TractorLinks.com
Show Parts for Model:
Re: Workmaster 641 electrical system
soundguy
06-03-2013 07:08:08
ground polarity is determened by look at which post of the battery is tied to the chassis.
gasser fords pre 65 left the factory as positive ground ( and 6v ).
diesel fords left the factory as 12v and negative ground.
you can setup a ford genny and run it as positive OR negative ground.
If you have an alternator on it.. it becomes less clear. the bulk of alts are 12v neg ground. but you can get 6v alts.. and positve or neutral(isolated) ground units.
wfd2
06-03-2013 07:55:52
 Re: Workmaster 641 electrical system in reply to soundguy, 06-03-2013 07:08:08
thanks Soundguy... I did a double check and it is 6v with negative ground. It runs, starts (except for the solenoid problem I have) and appears to charge properly.
Any ideas why this would be this way?
soundguy
06-03-2013 08:21:44
 Re: Workmaster 641 electrical system in reply to wfd2, 06-03-2013 07:55:52
who knows.
someone mighta thought it should been hooke dup like his new car in the driveway and did it.
it will run fine like that.
wfd2
06-03-2013 11:39:19
 Re: Workmaster 641 electrical system in reply to soundguy, 06-03-2013 08:21:44
During an upcoming restore, I should change it back huh?
36 coupe
06-03-2013 17:08:05
 Re: Workmaster 641 electrical system in reply to wfd2, 06-03-2013 11:39:19
If its working leave it alone.
Joe in Texas
06-03-2013 20:06:07
 Re: Workmaster 641 electrical system in reply to 36 coupe, 06-03-2013 17:08:05
a single wire alternator doesn't care if it is positive or negative ground.
36 coupe
06-05-2013 04:00:34
 Re: Workmaster 641 electrical system in reply to Joe in Texas, 06-03-2013 20:06:07
Bad info, the smoke will roll if you guess wrong.
soundguy
06-04-2013 05:38:34
sorry.. that's incorrect.
alternators do care what ground polarity they are hooked up to.
soundguy
06-04-2013 05:37:23
that's just um.. 100% incorrect. :)
