Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Ford 961 Diesel
Hal/ Eastern WA
05-30-2013 10:36:28
How cold is cold? If cold is 40 degrees, it probably would need to have the glow plugs working or have the engine heater plugged in for an hour for it to start right up. On the other hand if cold is 60 degrees, and it doesn"t start up after half a dozen turns of the crankshaft, you might have problems. And hopefully ether has not been used, at least very often.
I do not have experience with the row crop tractors, but really like my 641Diesel. It uses about half as much fuel as a similar gas tractor to do a given job. Even though it has way more than 10k hours on it, it still starts and works well.
As far as parts availability goes, most everything is offered by someone. There is a problem with rebuild kits for the 144 inch diesel--I have not been able to find any, anywhere on the internet. But kits for the 172 diesel are almost everywhere. And possibly there could be problems with getting specific parts to the row crop modifications. But in general, the hundred series tractors are fairly simple, and easy to keep running.
If in fact the tractor is a 961, it should have live PTO, which is a real advantage for certain jobs, like running a baler. The possible downside of having the live PTO is that it uses a double disc, 2 stage clutch, which is expensive to replace if that is necessary. The live PTO 5 speed transmission is possibly not as strong as the regular 5 speed, since the PTO power runs through a hollow transmission input and mainshaft.
Unless the overall tractor is really beat and the tires are poor, I think $1900 sounds like a pretty good price. Where is it? If you don"t decide to get it, maybe someone else would be interested. Good luck!
Colin King
05-30-2013 18:00:07
 Re: Ford 961 Diesel in reply to Hal/ Eastern WA, 05-30-2013 10:36:28
Great info, Hal. Thank you.
I'm going to go look at it again early in the morning with cash in my pocket.
Colin, MN
Ultradog MN
05-31-2013 04:56:10
 Re: Ford 961 Diesel in reply to Colin King, 05-30-2013 18:00:07
Good luck Colin. With your tractor/wrenching skills you should have no problem making the transition to a Hundred. It's certainly a lot cheaper than a 4 or 5000 and would do a lot of work till someday...
Hard to believe you couldn't easily get your money back if you decide to sell it again. As long as you don't 'restore' it.
Bring your camera! We like pictures.
Colin King
05-31-2013 05:06:50
 Re: Ford 961 Diesel in reply to Ultradog MN, 05-31-2013 04:56:10
Thanks, Jerry! I'll definitely take photos. And I totally agree...it's a step in a good direction, though will not likely replace the need for a thousand series sometime later on down the road.
Colin
